Home > Maintenance & Mods (L322) > Gearbox oil level check; On lift or On Wheels?
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Question in the title, how should you carry out the level check, on a two post lift or with the wheels on the ground....does it make any difference? If the car is supported on the lift at the chassis or jacking points is it level? All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #711567 11th Feb 2025 1:31pm
Pawl
There's no difference either way. Critical is to have the car level - which might be more likely with the lift dependant on the surfaces you've got available. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #711589 11th Feb 2025 7:00pm
