Home > Technical (L322) > PDM Passenger Door Mirror Heater Output failure
pcourtney
There seems to be a general electrical failure ( circuit short to battery or open) , the mirror does not clear the frost at all, whereas the drivers door one does pretty quickly
GAP IID error B1163-15 (2F) Left Mirror Heater Output
Has anyone had a similar fault, not the end of the world but annoying first thing in the morning Sad
Is it just simply a corroded wire or maybe disconnected along the wire path, which would mean changing the mirror would not solve the problem ( unless it is internal wiring inside the mirror which fails) - any heads up on the fault welcome please
Post #711764 13th Feb 2025 8:47pm
Merchy
A first step could be to pop the mirror glass out of the housing, and see what the condition is, that way you could check the condition of the wiring connection and heating element. It always seems to be the nearside mirror that suffers corrosion due to puddles / dirt etc against the kerb. Once popped out you could use a meter to check the connections.
You could pop out both glass sections and swop ( Just connect wiring, not fit in place obviously ) to check if the fault is with the glass or wiring feed.
Post #711793 14th Feb 2025 6:29am
pcourtney
confirmed, I took both heated door mirror glass off, then ran IID Faults again
Then put my working drivers door mirror on the passenger side, and no fault on that side, I looked carefully at the innards of the mirror, but could see no obvious signs of corrosion or discolouration, so I will just accept that after 13 years the heater element has died Smile
Post #712412 21st Feb 2025 3:05pm
Merchy
That is a good result, no messing around with wiring, and a cheap fix, decent quality replacements are about the £20 mark Thumbs Up
Post #712437 21st Feb 2025 5:27pm
