Home > Technical (L322) > Rear subframe refurb ballpark figure?
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Had my 08 S/C serviced at the indy and they've came back and said that my rear backplates are getting on a bit and could do with replacing.
Now I know from reading on here that that in itself is a big job.
I have a number of other items that have been advised.
    OSR upper outer rose joint has free play
    OSR lower supsension arm
    NSR lower suspension arm
    OSR subframe bushes
    NSR subframe bushes
    Parking brake engages but is weak, I suspect the cables need replaced.
I've not really got the skills or facility to tackle a job of this size myself.
The Indy wouldn't even quote me because of all the unknown siezed bolts.
Does anyone have a ballpark figure on how much it would be to do a refurb of the subframe?
This may be the deciding factor on whether I list it for sale this year. Crying or Very sad
Post #711891 15th Feb 2025 1:35pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Goggle Steve's steel. He sells remanufactured components including sub frame assemblies.
He also has a YouTube channel documenting work on his own L322.
Post #711943 16th Feb 2025 12:29am
dhallworth
I did the subframe on my old 4.2 SC and can tell you that it is a lot of work.
I recently priced all of the bushes to do my current car. Genuine Land Rover bushes are around £2k these days. The actual labour to remove and refit the subframe won't be much but all the time is in cleaning it, painting it and then replacing all of the bushes.
Post #712001 16th Feb 2025 9:57pm
