![]() | Home > General > Heated Seat Wiring Diagram |
andy vash Member Since: 15 Aug 2011 Location: uk Posts: 13 ![]() |
Can anyone provide me with a wiring diagram for a 2007 L322 front seat ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
probably the same as the earlier ranges so have you looked on rave or microcat online..
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Andy - I am not sure if the following helps or not...
according to rave there are heating elements in the seat cushion so the seat is not heated by hot air.. |
I can only pass on what Land Rover Cambridge told me, perhaps that explains why it took them 2 days... |
The problem is I have a 2002 Range Rover and in the past someone has installed seats taken from a 2007 model. I know this as I found a date stamp on the back of one of the seats
put a multimeter into the socket and turn on the heated seat switch and see what happens.. |
That will work for the feed but won't identify the heating element |
but once you have identified the feed then you can plug the loose plug into it...if you aint sure then whip the seat out and follow back the plug cable... |
