![]() | Home > Maintenance & Mods (L322) > L322 5.0 SC Vibration under light acceleration |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053 ![]() ![]() |
Found out how to log info on the gap tool and find it again here is a screen shot of the gear box on a run
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
My 5.0 fuel trims are almost identical to those. They've barely changed in the 8000 miles I've done since the timing chains were sorted.
Thank you David, dingg1 did say they were nothing you worry about but I want to investigate it just to be sure iv done everything I can before pulling the trigger on a new tc. If it needs the tc doing iv made arrangements with my mate and mechanic to do it for me.
So the latest scans of the engine plus turbine speeds each over at least 15 seconds at set constant speeds.
Deleted double post |
Here are the other screen shots from additional data we collected today on the run scan tool used....snap on.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1038 ![]() ![]() |
Sorry to take so long to reply. I've been away for a few days.
Thanks for getting back Phil.
Seems this shudder is historical to the car the service history shows a flush, filter and friction modifier add 15k miles ago. Ie shudder fix |
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 70 ![]() ![]() ![]() |
Mine was about 13k miles on from a gearbox flush when the judder started on mine, done by a LR indie for last owner. No have mention of any magic potion being added then. Happy to report that so far the refurb I had done has worked, even though it wasn’t economically sensible really. 2010 Supercharged |
Gsxr1250dave has kindly provided me with live values from his L322 for engine speed and turbine speed in a .csv file measured using the IIDTool, which makes it easy to see what’s going on. In the trace below you can see that the turbine speed is constant (because the vehicle speed is constant and the turbine is connected directly to the wheels via the transmission, transfer box and axle gearing) yet the engine speed is fluctuating by around 75rpm or so, at a frequency of around 1Hz. The vehicle speed for this condition is 55mph in 6th gear. Clearly the torque converter lock-up clutch should be locked solid in this condition and the engine and turbine speeds should be identical.
As the solenoids (including the EDS2 solenoid which controls the torque converter) have all been replaced with new ones, the only conclusion I can make is that the lock-up clutch in the torque converter is faulty (mechanical or hydraulic issue) and needs to be replaced. Phil Last edited by RRPhil on 31st Mar 2025 8:23pm. Edited 1 time in total |
Thanks Phil |
