Home > Technical (L322) > L322 Water Heater Control Valve
alexrusu1982
Romania 2008 Range Rover Vogue TDV8 Barolo Black
Hello, I have a problem with my L322 and I can't figure it out.
I have no heat in the car and the first
thing I changed was the Water Heater Control Valve. Everything was fine for 2 days after which I had no heat again. I changed the valve a second time with a new one and the same story. When I
unscrewed the hoses I noticed that I had no coolant in the passenger HEATER core at all. Has anyone else experienced something like this? The valve is a Hepu brand.
Thanks
Post #712157 18th Feb 2025 6:38pm
Gsxr1250dave
Your pretty much air locked in the heater core you need to get a hose on very gentle and flush it andvtry and connect it back up without losing to much coolant. Could also be a faulty secondary pump they do fail as well
Post #712170 18th Feb 2025 9:53pm
alexrusu1982
thanks for the reply.i will try tomorrow.
where can i find secondary pump
Post #712177 18th Feb 2025 10:19pm
Gsxr1250dave
Just follow yesterday single hose back and you will find it
Post #712178 18th Feb 2025 10:21pm
alexrusu1982
Thanks
Post #712179 18th Feb 2025 10:23pm
