![]() | Home > Maintenance & Mods (L322) > Sankey Trailer & Nato Hitch on a FFRR |
So is that link above saying the nato hitch is not type approved and thus can not be used on the road or just the normal 50mm ball to nato adapter isn't approved? |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
As far as I can make out Nato hitches are not type approved. It is ok to use one on a vehicle pre 1st August 1998
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118 ![]() ![]() ![]() |
I've got a Sankey Trailer that I have towed behind my D1 and D2. The plan for the FFRR is to use the Farmers hitch type affair, but with an extended shaft so it will sit out beyond the bumper instead of under it. This will then allow me to rotate it so it is a riser plate instead of a drop plate, which will keep the trailer nice and level.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Posted in error. John
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i thought the same thing! Must tow mine more often. |
In all honesty, the Sankey was bought to go with the 101.
Sankeys can be towed behind a FFRR but they do rattle/bang/jolt and generally make their presence known. I was going to buy one which had been made up as a camping trailer, nicely done too.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8094 ![]() ![]() ![]() |
I've done a lot of towing trips through France - and it really depends what you're towing. A good quality boat trailer with a nice low centre of gravity would be good well past 80 - not that I tried it of course ![]() But towing a Jeep - with a high centre of gravity, even properly loaded on a good Ifor Williams felt dangerous past 65
I expect a Sankey to be horrible at speed.... |
That's it, all trailers are different. I had an ancient beaver tail trailer, made from angle iron and with 16" land rover wheels and tyres. Used to wobble my volvo about all over the place at 60, was fine at 50. |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
I have a Sankey and a FFRR coming this week. In anticipation I got a farmer hitch solely for Sankey use. I'd like to get the height of it extended so the Sankey sits more level. Would like to see what you'll be using. Thanks. |
A friend has agreed to make the modified hitch, but he's a busy guy so it may be a while.
