Home > Technical (L322) > Auxillary water pump
kevinp
I've just put a new combustion chamber in the FBH to stop the embarrising smoke screen.
The water pump on the side of the FBH is working.
The auxillary water pump, down below the fuel filter has a fault to earth.
Can I presume the aux water pump is used when using the timed climate only?
Thanks Kev.
Post #712235 19th Feb 2025 4:37pm
