Home > Maintenance & Mods (L322) > Will a 2011 ZF 6 speed bolt up to a 2006?
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Brain Trust,
I recently won a Copart 2011 Salvage 2011 5.0SC L322. 94K on the clock and chains have been done!
In speaking with quite a few rebuilders - they think it is worth much more in parts than it is rebuilt...
Spent $2k after fees - would probably take another $2-3K and it may be worth $6k.
'They' say the engine is probably worth $4 alone and other than the front bumper back to the wheels - it is pristine. Transmission and Xfer are super smooth. Sunroof is smooth. I like the wheels... The seats are comfy, but black...
The drivetrain has >100k on it - how much of it do y'all think would bolt on to my 2006 4.4NA Jag V8 'Petrol'?
Pretty much the rest of it can go.
I would love to her any though you have. JDW 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #712276 20th Feb 2025 7:18am
GraemeS
Australia
At least the TCM inside the gearbox would have to be swapped because of the different CANBUS protocols.
Post #712286 20th Feb 2025 11:14am
Depends on how far you want to go.
If you stripped the 06 back to the shell you could probably modification most of the bits on the 5.0 to go onto it. I reckon most of it would swap over but you would probably have to do a whole transplant of the electrical system and wiring loom to make it function….. There is nothing that can't be fixed with a hammer😜😜
Post #712517 22nd Feb 2025 5:22pm
