Home > Technical (L322) > 3.6 TDV8 inlet manifold/cam cover grommet
MarianaWestminster
Hi all,
I'm trying to find the part number for the little metal/rubber grommets that pass through the cam cover and hold the gasket in place on a 3.6 tdv8.
The cam cover bolt then goes though the center of these and into the head.
I'm in the middle of a gasket replacement due to oil leak and I've managed to loose one.
I've checked the JLR classic website but they aren't shown as a seperate item or the bolts for that matter.
I don't have a picture to hand right now but will update with one tommorow.
Many thanks
Post #712448 21st Feb 2025 7:35pm
MarianaWestminster
Shamelessly pinched from Life as Usuals excellent youtube series on this job.
This is the part I'm after the part no for just in case I can't find the lost one!
Post #712449 21st Feb 2025 7:41pm
MarianaWestminster
Luckily I found the one I lost hanging out on top the steering rack so this part number is no longer required Thumbs Up
Post #712636 23rd Feb 2025 9:03pm
