Home > Technical (L322) > p123a22 Engine System Fault and Limp Mode
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
3.6 TDV8, Can anyone give me a pointer as to where I start with this one. Have done a search here and can't find anything.
Code description in manual is Barometric - turbocharger boost sensor A (right-hand manifold absolute pressure temperature [MAPT] sensor) correlation.
It has happened a couple of times in the last week, Bong and Engine system Fault message and Limp mode. Turn off and on and all OK. Seems to occur under load. Code can be cleared and then reappears. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #719497 9th Jun 2025 9:06pm
Paddy X350
So I replaced the right hand MAPT sensor a few weeks ago and so far so good, no more bong and engine system fault, but tile will tell.... All the best
Chris
Others;
2003 Jaguar Xjr
Post #720596 30th Jun 2025 10:36pm
