![]() | Home > In Car Electronics (L322) > 07 L322 Display stuck in Land Rover logo / no sound |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 105 ![]() ![]() ![]() |
Hi
lucasvrooij Member Since: 10 Feb 2021 Location: Breda Posts: 7 ![]() ![]() ![]() |
Partially, bypassing the bouetooth module AND the TMC module in the rear left compartiment got the nav display working again. However I am still stuck on the radio function and cannot use AUX. |
Thanks. I have all the same problems. I have a fiber optic signal to the TMC unit. But it stops there. If i unplug and plug in the tmc module it creates a signal for 30 seconds. But i thought the signal startet in the head unit og unit before ut. I have bought a lot of the units for this used now. Will let you know if that solves anything |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 93 ![]() ![]() ![]() |
I have read posts related to the problem being a dead CD changer. Getting it out to test this is a bit tricky - but you can see if you have a laser light on the connector (going into the CD Changer , then the outbound one) to see if thats not the problem).
I just replaced my touch screen with a replacement. everything now works again (aga aux, volume button etc). Took me two hours. Not difficult at all. |
