Home > Maintenance & Mods (L322) > M62 Engine - Vacuum questions - advice required
joncorry
United Kingdom 2002 Range Rover HSE 4.4 V8 Tangiers Orange
Hi, my L322 G4 hasn’t had a huge amount of use over the past 7months due to house moving etc…
On the drive up from Cheshire to Cumbria, my wife drove the RR and complained the brake pedal was really hard but the brakes felt really bad with poor stopping ability.
The last job it was was f>r brake lines but that was done by a reputable independent LR specialist and although some people have said, bleed the brakes, I’d have thought they would be spongy with air in the lines, not hard.
Looking at the vacuum side of things, the hose from the servo to the pipe that runs around the back is in good shape and connections are snug. The pipe itself seems in good order, no obvious splits or holes.
I have taken pics of things are puzzling me though and would appreciate help.
Question 1 - there is a white pipe that doesn’t seem to be connected to anything, is it a breather or should it be connected to something?
Question 2 - The line that clips on to the inlet pipe has a damaged clip so it’s not seating nicely.
Does anyone know the part number for this line as I can’t see it on JLR Classic or Advanced Factors?
Question 3 - I took a pic of the PCV and it looks to have a light misting of oil, sign of failure?
Question 4 - the right angled elbow and the pipe its connected to weren’t originally joined, should they be? They seemed to be in the right place, just not together.
All helpful suggestions welcome. Just to confirm, it’s a 2002 M62 4.4 V8.
Thanks! 2002 L322 4.4V8 - G4 Challenge Car - Australia leg
2003 Defender G4 110
2008 Discovery 3 G4
2009 Defender 90
1968 Series 2a
Post #712757 25th Feb 2025 1:00pm
1, Pretty sure that is a breather from the starter motor...
2, No, sorry
3, I'd clean it all up and see where the leak comes from....
4. I should think so....
About the brakes, sounds like on or more seized callipers to me.... Pete
Post #712764 25th Feb 2025 3:53pm
joncorry
Cheers for the reply Pete. I’ll check out the callipers for sticking. 2002 L322 4.4V8 - G4 Challenge Car - Australia leg
2008 Discovery 3 G4
2009 Defender 90
1968 Series 2a
Post #712766 25th Feb 2025 3:58pm
