![]() | Home > Maintenance & Mods (L322) > Sunroof not fully closing at the trailing edge |
| Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 787
With the ignition on, press the sunroof button and hold for about 30 seconds or until you hear a click then open it fully and close again and that should do the trick. Hope this helps, it worked for me. |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310
Thanks BB - when you say press the button, do you mean push it towards the front of the car, as if closing the sunroof ? |
Sorry Jonny, push the button upwards as if you are opening it for vent position. |
Smashing - many thanks. I’ll give it a go tomorrow. |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Press and hold it for what feels like an age until you hear it click and reset 👌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
There's instructions in the workshop manual on how to reposition the glass. I had to do this on mine to get it to sit right as resetting it didn't work. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Thanks all - it worked a treat ! I do love a simple fix and it’s great to have such a helpful resource in the forum.
Glad to be of help Jonny, that's what we are all here for. What's this with the swapping of the dab to dab+? Not heard of that before and what does it do extra? |
Most elderly L322s have the standard DAB unit fitted. In fact I think they all have standard DAB. DAB+ is a better, improved version of DAB that was fitted to L405s L494s etc. It has more channels and generally is a very worthwhile upgrade. Only issue with it is the electrical systems generally weren't built to work with DAB+ however there is a workaround.
Sounds like too much of a faff for my liking lol. |
Once the module is in accessing DAB becomes second nature. If you switch the car off with DAB selected it’s still functional, so you don’t need to switch between the different modes. Most people listen to DAB over FM, so shouldn’t really be an inconvenience if that’s the case.
| All times are GMT |
