Home > Technical (L405) > Tracking L405
DrF
Tracking L405
Afternoon All,
After some advice, i think i may need my tracking on my L405 as car is pulling slightly to the left may be as a result of a pothole probably!!
Who should i use please? I don't have lane assist, so in my simple mind this should be a fairly straight forward exercise... famous last words.
Your help and advice would be welcome please.
kind regards
Dan
Post #713380 5th Mar 2025 6:22pm
easy, the hunter alignment system seems to be the best around.....finding a capable company is harder.
kwick fit have this system and my local branch in swindon did a good job , after i made clear that my 05 personnel reg wasnt related to a L322 but a L405.. ... - .- -.
Post #713384 5th Mar 2025 6:53pm
Yep, deffo Hunter system. If you get a good place/bloke you can stand and watch them do it with all the numbers appearing on the screen and going from red to green. Spot on is a big ask but they can get very close (centre of the green) if the bloke is good and not too rushed. Its a bit if an art as changing one will slightly affect another so its not just a case of getting one corner right and then moving on. Would be handy to have a note of what the numbers should be so that you can be sure they're changing them to the correct car!
My nearest with the system is a National Tyres place. They're normally dealing with very ordinary fare so when I took a Lotus down they treated me like royalty...and did a great job. Mike - MPx
Post #713385 5th Mar 2025 7:50pm
Couple round me who have a hunter or similar. I tend to use the Formula One auto centre in Burton. And they do a decent Job.
I’ve got to get my D5 done and I’ll be taking it to them in the next week or so as the steering wheel is off to the right a tad and it is annoying me….. only a degree or so but noticeable. There is nothing that can't be fixed with a hammer😜😜
Post #713386 5th Mar 2025 8:07pm
DrF
Evening Chaps,
Thanks for such a swift response, I will get booked in, but in true RR style a bigger problem occured this evening which will need fixing first, new post to follow.
kind regards
DrF
Post #713401 5th Mar 2025 11:47pm
If it was pulling left under braking then that could be connected with your latest post...!! Pete
Post #713413 6th Mar 2025 10:38am
DrF
Morning Haylands,
That's an interesting theory. I hadn't thought of that.
I will get them to check when it's being repaired, just got to get it recovered now.
Dr F
Post #713414 6th Mar 2025 10:47am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
do you still have to put it into tight alignment like on the l322 ? or am i thinking of something else ?
Post #713419 6th Mar 2025 11:56am
