![]() | Home > Technical (L322) > Lower Tailgate Electrics |
Does anyone know how the electrics for the tailgate 'route' as i've replaced the wiring loom for mine as ssomething has happened to it previously, likely involving some sort of ape |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35803 ![]() ![]() |
dont know exactly what you mean by 'route' mr pleb, but the wiring comes in through a rubber sheathing and goes both left and right on the tailgate..btw the carpet bit comes off very easily.. |
Right i've replaced the harness, both solenoids on both sides, a new switch as well and still can't get the solenoids to fire when the button is pushed |
cheers NDF I'll give it a check over tomorrow. May be the relay is fried as well as the wiring wa a right dogs dinner when i got to it |
Well checked fuse 16 in the rear fuse box and its a good un |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Jeez, I thought they were plenty light enough already - I think it would only be half the weight of my old Classic's tailgate. Maybe save your pennies and buy a gym membership? ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
2011 models have a strut on the right hand side of the lower bootlid to stop the boot crashing down when you open it... Is that what you mean?
Might have a nosey at the dealership if im passing sometime craig and see if its what im after as its likely going to be the cheaper option |
Ok as an update i've ploughed into raves electrical document and found pages 24 + 43 seem to show that the following happens;
Well i've looked at my fusebox doesn't match the one from RAVE |
http://www.rangerovers.net/outfitting/towi...onnections
Cheers scarey I guess the 5 pin relay is missing then |
can you not take one out from somewhere else and try to make it works ok. |
Fraid not as it's one of the oblong not squares and only other one in there is a 4pin unit |
