Home > Technical (L322) > Electric Parking Brake Switch
Bigbangman
United Kingdom 2006 Range Rover Vogue SE TDV8 Java Black
Hi,
Apologies asked before but information I got related to manual handbrake console
Stuck with this !
Need to change my EPB switch but can’t see how you remove the centre console which I assume has to be done to access the four screws
I could have ago at attacking it but prefer to do it without damage
Found all the info on removing the earlier type without EPB but can find nothing for the later facelift with EPB switch in workshop manual
Any one got any instruction / video
Thanks If its not broke now it soon will !!!
Post #714009 14th Mar 2025 9:27am
dhallworth
Is it definitely your switch that's at fault? They rarely fail.
Instructions are in the 3rd post on this thread:
https://www.fullfatrr.com/forum/post195539.html
I removed mine to replace the handbrake switch but it turned out to be a corroded wire in the rear left wheel arch.
Post #714064 14th Mar 2025 8:50pm
Bigbangman
Hi David,
Thanks for info, but question asked relates to Freelander, looks like this went on 322 by accident
Have listed on correct site now
Regards If its not broke now it soon will !!!
Post #714073 14th Mar 2025 10:42pm
