Home > For Sale & Wanted > [For Sale] L405 rear calipers with actuators - genuine LR
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
£200 for the pair. The calipers are in need of refurbishing. Actuators working fine.
Please message if my pricing is way out. I believe that new these parts would be over £400 each fr caliper plus actuators.
They are from a late 2012 L405 4.4 Tdv8.
 2012 SDV8 Vogue SE
Post #714700 23rd Mar 2025 10:25pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
hi
do these take the 365 mm discs ?,you got any photos as well please
thanks
Post #714716 24th Mar 2025 8:30am
bozmandb9
Yes, they take 365mm discs, I'll get photo's.
I can have them refurbed by my garage if you want, and painted whatever colour you wish, but this would be at additional cost. 2012 SDV8 Vogue SE
Post #715139 29th Mar 2025 8:27pm
will308f
hi have you had a chance to take some photos ?
thanks
Post #716099 14th Apr 2025 12:44pm
Gremlin500
The calipers have different mounting brackets according to disc diameter, so if both cars were fitted with the “performance brakes” option (all V8’s) you are good to go, check this picture of the two types, the difference is hard to notice:
There are also TWO types of actuator plug:
Make sure to check carefully Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #716100 14th Apr 2025 1:20pm
will308f
@gremlin is the difference in the length of the arms ?
Post #716101 14th Apr 2025 1:38pm
Gremlin500
Yes correct, it’s equal to the difference between the radii of the two different brake discs.
The calipers are identical, only the brackets change according to disc diameter.
V8 = 380mm front, 365mm rear.
V6 = 365mm front, 350mm rear.
So, the “bigger” brackets are +7.5mm longer than Standard.
Same caliper, now sits 7.5mm further out from the axis.
The Right/Left “offset” of the calipers/discs are identical between both types, so no concerns when upgrading say V6 brakes to V8 brakes, as I have done on my V6 L405.
Not a concern if both donor & recipient vehicles are both V8’s. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #716102 14th Apr 2025 4:10pm
