Home > Technical (L405) > Random One Need Help
Britishlion
Evening
Got a 14 plate FFRR vogue 4.4 , 140k runs great but once in a blue moon the car the will go into limp mode there is no rhyme or reason for it and been changing everything buyt getting the ends of my knowledge with it
Its had new fuel rail , sensors etc etc all reading ok but when it goes in to limp i get three codes
P00CF-62 Barometric Pressure Turbo/supercharger boost sensor a correlation
Po235-16 Turbo charger boost sensor A circuit
P0088-17 Fuel Rail / sysem prssure to high
anybody had this issue or seen a common fault that could cause it ? the car can run perfectly for months and then bang , back into limp mode
Thanks
Post #715561 4th Apr 2025 8:48pm
GraemeS
Australia
Has the fuel pressure sensor connector wiring fix been done?
Is the MAP sensor clean? L405 D350 SE Carpathian Grey D5 19" rims
Post #715564 4th Apr 2025 10:18pm
Britishlion
Not sure actually ? is this a none problem with the fuel pressure sensor
MAP sensor changed already
Post #715585 5th Apr 2025 10:32am
