![]() | Home > Maintenance & Mods (L405) > L405 potential problem ahead? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Sounds like a leak from the airbags, raise it to off road height, you may be able to hear it.... with the engine off obviously...!! Pete
Oh, and it's a "now" problem, the compressor will be working overtime to keep air in the system, leave it too long and you will need a new one...!! Pete
BasherBishop Member Since: 12 Feb 2025 Location: Lincoln Posts: 11 ![]() ![]() |
Thanks for the sound advice! I'm now on the case. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278 ![]() ![]() ![]() |
I have almost the same car and there is an option out have it automatically lower to access mode upon parking.
I'm not convinced it's that because it's only the front that lowers. I will check though!
alaska1993 Member Since: 19 Feb 2025 Location: Brasov Posts: 17 ![]() ![]() ![]() |
I just bought my first Range Rover, an L405 and it was set to lower when the car was in park. It drove me nuts. I was able to disable that feature. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1879 ![]() ![]() ![]() |
Ummmm, there are 2 schools of thought on this:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
I’ve got auto access off on my 405 and D5. Drives me up the wall. I leave it off and make sure to raise and lower the suspension often so as to give the bags and compressor something to do!
Well Gremlin. After reading your post , things are much clearer to me now, it makes so much sense. Now I'm in a trance like state:) |
I think I will turn auto access height off too, it drives me nuts, if I had one airbag leaking? Would both sides lower? Because both my front wheels lower when this happens. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
you parked on a slope? sometimes the FF will try and level .. ... - .- -.
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 150 ![]() ![]() ![]() |
I think this is nonsense. When I got my P38 in 2009 at 65K miles, I changed all four airbags. They are still on there, the odometer reads 200,000 miles. They don't leak. As far as I am concerned, they are fit and forget. The 99% of wear will occur as the suspension goes up and down at normal height, and there's nothing you can do about that apart from not drive it! Chris. L405 - 4.4SDV8 Vogue P38 - 4.6V8 HSE Land Rover series IIA V8 |
Potential problem ahead? Solved!
