![]() | Home > In Car Electronics (L322) > Fibre optic cable route |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 46 ![]() ![]() ![]() |
The Most signal runs in the following order
Varks74 Member Since: 03 Apr 2025 Location: Cornwall UK Posts: 17 ![]() ![]() ![]() |
Cheers for the info bud,
Try reversing the most cables at the touch screen. if that does not work it looks like the touch screen could be faulty, try substituting one that is known to work and see if it solves the problem. As you have already proved that bypassing the touch screen gets the most light through to the boot, the touch screen or the way the most cables are connected to it are your problem |
yeah that is next on my list, someone sent me the wiring diagram for the touch screen and it shows which fibre optic cable is the input and output, so will check that, i now have 4 screens (long story) 2 of which i know are working, so definitely not a faulty screen, i did wonder if one of the modules in the boot was hard wired to the touch screen, like the amp and the screen isn't allowing the signal through due to that, the previous owner replaced the amp but that wasn't the original fault as the touch screens power light wouldn't come on before, ended up being the IHU, so maybe the amp fitted is now faulty, just need to strip out the rest of the rear trim so i can get access to the amp and maybe swap that out and try again, i just hope i can remember the sequence for the optical cable harness when it all goes back in!
I did find this online, it was an AI answer to whether a faulty amp would still allow an optical signal to the rear modules, but it would explain my issue:
