![]() | Home > Technical (L322) > TDV8 4.4 Oil leak from front directly under engine. |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 275 ![]() ![]() ![]() |
See if the front of the engine is wet, that’s down where the aux belt and pulleys are. That’s generally a front crankshaft oil seal. If it’s dry then the oil cooler can leak and if it hasn’t been done before it will need doing at some point. Another common area is the two o rings that go on the oil cooler feed pipe.
Monkey456 Member Since: 15 Apr 2025 Location: North East Posts: 5 ![]() ![]() ![]() |
Thanks JonnyCJ will do, much appreciated. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
It's worth checking that the steering rack isn't leaking. Mine went in for a supposed diff leak but it turned out to be the rack. |
Thanks Kevinp will do, much appreciated. |
Rove Ranger Member Since: 22 Mar 2025 Location: England Posts: 39 ![]() ![]() ![]() |
Was that a new rack to sort it, Kevin? |
Yes mate. Luckily under warranty. |
Looking at the pics again, I’d start at the front. Oil blows back as you drive, so if there’s oil at the front, it’s likely to have come from the front. |
