![]() | Home > Technical (L405) > Oil level |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Hi Guys. Thought I’d check my oil level and it’s showing as underfilled.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1437 ![]() ![]() |
I would start by Buying a vacuum pump (Sealey 10L suits me) and extract the oil and measure the quantity, you will know then that the oil sensor is correct. Replace with new oil (C1 presume its a 4.4 diesel?) I usually put in 9.3L of new oil (it will be different if it's a 3.0 diesel) and change the oil filter and then reset the service indicator.
Think I'll do this, I've been trying to find a C1 or C4 5W40, but think I'll have to admit defeat, and stick to 5W30 C1! 2012 SDV8 Vogue SE |
The problem with this is confidence. If I buy an extractor, and get 8 litres out for example, it may be that my oil level was low. Or it may be that I have not successfully extracted all the oil on my first attempt with a new pump. Also, do we really know exactly how much oil should come out with a pump? I guess in a perfect world you get 9.5 litres out and put the same back in. But if you get 7l out, put 9.5 litres in, I guess you could be taking a massive risk! 2012 SDV8 Vogue SE |
In that case use the drain plug! 2018 SE SDV8 4.4 Byron Blue |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1362 ![]() ![]() ![]() |
The pump method gets virtually all the oil out. It starts sucking air when all the oil is extracted.
janpel Member Since: 13 Jun 2022 Location: Harderwijk Posts: 2 ![]() ![]() ![]() |
I did a test on a 4.4 and 3.0 SDV, first took all the oil out with a vacuum pump and then took out the sump plug. In both cases there was hardly any more oil coming from the sump.
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
I’m in the same boat. Recently serviced by Stratstone and it’s showing underfilled on the gauge but bang on the minimum. Guess if they always do this they can save nearly 2 litres in every oil change the savings to them will add up over a year! I’m a sceptic and a pessimist!!
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
I have the opposite to most, using the vacuum method I get 8 and a bit out so I put 8 and a bit back in. The electronic indicator on the dash reads full, I wonder if it’s reading under and I should add another litre, would it do any harm if it was overfilled anyway? Or for that matter what if it did only have 8L in? Geoff |
Halfords do a synthetic 5W-30 C1 to the Land Rover and Ford spec for the 4.4 engine. Halfords put out orders to the oil suppliers who blend oils from Castrol and another oil co (can’t remember at the minute) which is fine for the V8. Shell/castrol/mobil etc are all over priced due to marketing and advertising. Normally I use Opie oils and buy Valvoline oils. Opie sell them in 5litre containers and are reasonably priced. Regards Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 57 ![]() ![]() ![]() |
Just a recommendation..used this for years in the D4, now in the L405 V8.
