|  | Home > Maintenance & Mods (L322) > Engine misfire P0300-00 P0302-00 P0304-00 P0308-00 |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | Here are the codes as in the image, to aid in people searching in the future:
|  19th Apr 2025 9:50pm |
|  13th May 2025 9:23pm |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | Nm | ||
|  13th May 2025 11:10pm |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | Just for grins, i started the car without the connector plugged back in.  Runs about the same and the codes are the same.
|  13th May 2025 11:14pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | A sensor won't do any harm to try but the 5.0 engine is known for timing chain issues. They are caused by wear on the guides from the stainless steel pin on the tensioner. It's a well documented issue and one I've come across on my own car.
|  13th May 2025 11:18pm |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | ‘12 5.0 Supercharged.
|  13th May 2025 11:27pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Mine was a 2012 that needed the chains doing too.
|  13th May 2025 11:34pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Also, you've got 4 camshaft sensors on that engine. You could swap them around rather then buying a new one and see if the fault stays with that bank or follows the sensor.   | ||
|  13th May 2025 11:35pm |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | Good idea!
|  13th May 2025 11:36pm |
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33    | A new sensor fixed the problem.  All codes are gone and the car is running great again!
|  26th May 2025 10:09pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
