Home > Technical (L405) > Would an 4.4 TDV8 engine go in an L405
MH04
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I don’t know the right place to ask this really but the bottom end in my L405 SDV8 has gone and I’ve been offered a 4.4 TDV8 engine out of an L322 from a breakers.
I know it’s pretty much the same unit but would one go in an L405 as a replacement, it’s only the crank and possibly the pistons etc that would be needed.
Post #716935 27th Apr 2025 9:01pm
GraemeS
Australia
A new L405 4.4 engine has been fitted to an L322 by a forum member. The sumps are different and the ancilliary belt and pulleys are different so would need to be swapped. L405 D350 SE Carpathian Grey D5 19" rims
Post #716937 27th Apr 2025 9:37pm
MH04
So in theory it could be done?, I’m just wondering as all the ancillaries on my L405 are ok, it’s the crank that’s knackered, so an L322 block could work?.
Post #716941 27th Apr 2025 9:53pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Block, pistons, conrods and crank are identical between the two models. When I rebuilt my L405 SDV8, all I could source was a L322 short block and used the crank and block. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #716944 27th Apr 2025 9:58pm
