Home > Technical (L322) > Transmission fluid - Recommendations ????
Crusty21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I see a lot of guys on here are happy with the Smith and Allan engine oil.
Any thoughts on the Smith and Allan Lifeguard 8 transmission fluid?
The ZF stuff is around £30 / litre Sad .... and to be safe I'd probably buy 8 litres.
8 litres of Smith and Allan £60 Very Happy
I'm just about to change the gearbox oil (not a flush), pan drop & filter only. 2011 TDV8 4.4 Vogue SE
Post #717069 29th Apr 2025 2:20pm
dingg1
The gearbox guru rr Phil recommends to use the zf, that's good enough for me.
Engine as long as it meets spec suits me, but I have stuck to the zf for the box
Post #717074 29th Apr 2025 2:43pm
dhallworth
I had Smith and Allan Lifeguard 6 equivalent in my 4.2 SC and have had it in my 5.0 SC for 2 years now with no problems. It shifts perfectly and has towed 3.5 tons with no funny behaviour.
Post #717076 29th Apr 2025 2:52pm
Crusty21
Just can't figure how S&A is 25% of the price of ZF Very Happy Very Happy Very Happy Very Happy Very Happy
I use the S&A engine oil and the vehicle runs great on it. It's that quiet sometimes I think i've stalled Laughing Laughing 2011 TDV8 4.4 Vogue SE
Post #717079 29th Apr 2025 3:13pm
winco
I use the Westway Oils version in my XF Sportbrake with the ZF8 speed. No issues and is much cheaper the the ZF 'Lifeguard'. A name like that panders to the worry aspect of human emotion.
A 20l drum means you can do an interim flush instead of a simple drain and refill that will always leave old oil in the torque converter. 2010 5.0 SC Autobiography Overfinch in Bentley Silk White pearlescent, 22" Overfinch wheels with 285/35x22 tyres
Post #717114 29th Apr 2025 9:24pm
RRPhil
I agree that Lifeguard Fluid 8 is eye-wateringly expensive. The only ‘official’ alternative, according to TE-ML 11, is Petronas Tutela Transmission AS8, but I think that’s even more expensive than Lifeguard 8 in the UK!
Autodoc sell Lifeguard Fluid 8 for £21.41/litre, which includes free delivery but, in my experience, delivery from them is very slow.
The fluid change interval recommended by ZF is 93,000 miles/150,000 km so I guess you’re only likely to do this once during your ownership, but you’ll have to decide if it’s worth the extra £111.
The typical remanufacture cost for an 8HP70X is around £3,500.
Phil
Post #717127 29th Apr 2025 11:47pm
Crusty21
Many thanks guys Thumbs Up
i'm still a little unsure what to do but the picture is a lot clearer Very Happy
Cheers
Neil 2011 TDV8 4.4 Vogue SE
Post #717131 30th Apr 2025 6:16am
toby1
ZF doesn't make the oil, does it? - what company does, I do not know.
Surely someone, somewhere has analysed it hence why there are other suppliers. Is it any different from Dexron ATF? Who knows?
I suspect there is a bit of doom and fear spread about, but that is just my opinion. 2012 Vogue TDV8 in Aintree green over sand
Post #717133 30th Apr 2025 8:11am
Rambles
Plenty of sellers on eBay offering ZF fluids
A few odd lot litres of ZF 8 for a tenner
In addition to S&A, there is also Westway
https://www.ebay.co.uk/itm/126515711470?mk...media=COPY
At the price of the Westway, no reason why the transmission fluid should not be part of yearly maintenance
Post #717134 30th Apr 2025 8:22am
cass
When someone with the knowledge and experience of RRPhil makes a suggestion about gearboxes I will follow that to the letter.
If using something different only saves £100 during your entire ownership then it becomes a complete no brainer for me.
£100 is a drop in the ocean of Rangerover ownership costs.
Post #717146 30th Apr 2025 10:59am
pcourtney
my local Land Rover ( Range Rover ) indie has used Motul for the last ten years or more, he swears by it, under £10 a litre in bulk, but available online for 20% more from Opie Oils
Motul ATF VI Fully Synth Automatic Transmission Power Fluid
https://www.opieoils.co.uk/p-90043-motul-a...fluid.aspx
Oil manufacturer recommendation ZF Lifeguard 6 Plus
Oil manufacturer recommendation ZF Lifeguard 8
Oil manufacturer recommendation ZF Lifeguard 9
Post #717158 30th Apr 2025 1:33pm
Rambles
Could be interesting to know what Bodsy uses when he does transmission fluid changes on the 8 speed boxes
I recall…but i could be wrong…that he does not use lifeguard 8, but uses a suitable alternative
Anyone that has used Bodsy recall? Was it Febi Bilstein fluids that he uses?
Post #717181 30th Apr 2025 9:02pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I purchased 20L of Smith & Allen Lubeguard 8 last summer and used it to do a full flush (drained a refilled 4 times) and replaced the filter pan with the vehicle having done 60k miles.
It made a noticeable improvement to the smoothness of the shift/drive and has been great for the last year.
I plan to do a basic drain and refill this summer, again using Smith & Allen. I will probably add this to the annual full service regime.
As others have said, ZF don’t make oil, so they must be buying off an oil producer/blender and packaging it as their own. No reason why Smith & Allen is not as good as the stuff that comes in ZF bottles, but without the mark up for marketing/brand.
Post #717183 30th Apr 2025 9:49pm
Roverlander
United States 2007 Range Rover HSE 4.4 V8 Stornoway Grey
I've used the Factory ZF Fluid in the past and just did a service with LiquiMoly Top-Tec 1800 and haven't noticed a difference.
Post #717186 30th Apr 2025 11:18pm
p38arover
Australia
For Australians, Penrite claim their ATF BMV is Lifeguard 6, 8, and 9 compatible. For the earlier 5HP trans they claim their ATF MHP is Lifeguard 5 compatible. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #717205 1st May 2025 10:55am
