Home > Maintenance & Mods (L405) > Constant Tension Hose Clamps Warning...
Following on from
https://www.fullfatrr.com/forum/topic67828.html
I noticed a wet patch on the drive just behind the nearside rear wheel, it's been there a while, usually hidden by condensation dripping of fatty and masking it, anyway this morning it was the only wet patch, I guessed what it would be...??
(yes I know it's dirty, see below)
Off to borrow a ramp, wheel and arch liner out and it reveals the coolant and air conditioner pipes that pass through the arch to the rear HVAC unit.
This was the two coolant pipes I changed when I did the ACE pipes, the constant tension hose clamps seemed OK but one had failed and was weeping, not a great amount... Although it certainly pi55ed out when you touched the pipe and moved it a few mm's.
I've never really trusted these hose clips, always found jubilee clips to work better, but they do seem to be everywhere...
I replaced the clip with a jubilee clip and all was back together and water tight again...
New clip in red, old constant tension clip in yellow, thought it might as well stay there as it's loose and not squashing the pipe at all, saved a drain down...
The brown stuff was put on when the pipes were changed, it's Dinitrol ML, just to help with any salt thrown up here...
Back home and gave it a good wash, the ceramic coating (bottom of this page https://www.fullfatrr.com/forum/topic64965-75.html) made a huge difference, so easy to clean it and leave it looking like new again....
So watch these clips they are far from infallible!!
Thumbs Up Pete
-Click here for Thread-
Post #717089 29th Apr 2025 5:36pm
dhallworth
At least it was a nice easy fix, Pete.
Car is looking cracking in that blue too 😍
Post #717109 29th Apr 2025 8:55pm
Cheers David, yeah, easy enough, it took several times longer to remove the arch liner than fix the leak..!!
It does look so nice when it's clean, and it's sunny... Thumbs Up Pete
Post #717139 30th Apr 2025 9:36am
fisha
Interesting, I’d noticed a patch in a similar area in recent times as well, but thought it was further back and put it down to the tailgate or something holding water.
I’ll need to have a closer look. V8 or else ...
Post #717171 30th Apr 2025 5:06pm
If you look up between the rear silencer and the bottom of the arch liner you can just see the pipes... Thumbs Up Pete
Post #717184 30th Apr 2025 10:36pm
