Home > Technical (L405) > No TPMS information on dash panel menus.
Bikeracer
United Kingdom 2014 Range Rover Vogue SE SDV8 Nara Bronze
I have a 14 plate 4.4 Vogue and I cannot find any information in any of the menus about tyre pressure monitoring.
There are no TPMS valves on the tyres, would this explain the reason for not having a section in one of the menus?
Was it not fitted to some models?
Post #717214 1st May 2025 12:12pm
dingg1
Someone who got Censored off with the spurious notifications had it coded out of your vehicle
Post #717218 1st May 2025 1:14pm
Gremlin500
Yes, that may be so, it can be the cause of much annoyance.
If you have a GAP iiD tool, you could check if the TPMSCM is still present, or just not configured in the CCF.
The TPMSCM is above the drivers’ head under the front of the headlining, it’s quite a small box. V6 Vogue - “Less is More” - less to go wrong!
Post #717224 1st May 2025 3:08pm
Bikeracer
Thanks for the answers.
I don't have a gap tool so I can't check, however after three years of not knowing it was missing I don't really feel inclined to now sort it out.
However, the next time it goes into RRW at Grantham I'll get it cheked and consider if the cost is worth having it sorted.
Post #717229 1st May 2025 4:09pm
I can't remember when it became mandatory, but on a 14 plate it was still optional, so in all likelihood you don't have it.
Mines a 63 plate and I'm glad to be without it as it caused me no end of problems on my L322's.
Post #717239 1st May 2025 5:34pm
knwatkins
TPMS only became mandatory at the end of the 2014. As above, the original purchaser probably didn't buy it. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #717255 2nd May 2025 7:32am
