Home > Technical (L405) > Please help
That405
England 2014 Range Rover Autobiography SDV8 Carpathian Grey
Please help
Please could someone help me..
I bought a l405 sdv8 4.4 2015 from a garage that I’m having trouble with and I need to find some genuine information..
I could do with a copy of the service guide
Proof of oil max fill
And if possible oil amount when car is at minimum..
Thanks in advance
Post #717254 1st May 2025 10:53pm
Look in our wiki, there's a workshop manual download...
You could do a forum search as there's a wealth of info in members posts. ... - .- -.
Post #717256 2nd May 2025 7:56am
diesel Dave
Not sure what you mean by proof of max fill. From oil and filter change they take 9.4 litres to full, all segments should be yellow on the dash when checking level if full. From full to minimum is one litre so below 8.4 litres is considered below minimum level. Hope that makes sense.
Post #717257 2nd May 2025 8:07am
That405
Thanks I have downloaded that but can’t seem to find anything about the oil change procedure
Post #717259 2nd May 2025 8:34am
That405
So I bought the car from a dealer and was meant to be serviced and by time I got home the car was on ( minimum engine oil level underfilled )
So what I need when I say proof if a page in the manual what says it’s 9.4L fill and also what the oil amount you’d have left in the sump and the lowest point so I can work out what there saying is not uncommon oil consumption. It was a 45 minute drive home.
Post #717260 2nd May 2025 9:02am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Page 2 here (from the WSM): -
https://www.fullfatrr.com/gallery/albums/u...ATIONS.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #717261 2nd May 2025 9:09am
That405
Thank you
Post #717262 2nd May 2025 9:17am
Kot
Welcome
https://www.ownerinfo.landrover.com/model/...nt/1390617
Buy a vacuum pump search oil change and you will find many recommendations I use this had it 4 years and its ideal for me it holds 10L. Suggest you find Baltic Blues post on procedure Thumbs Up Change the oil yourself if you have no confidence in the last garage in the long run you will feel better who knows what they put in, if at all they did change the oil?
Measure what comes out and only put low saps C1 oil back in, Opie do good deals input reg and choose oil and oil filter. Most of us change the oil 2-4 times a year take heed of service warnings as fuel dilution of the oil is common. Oil filter change is simple get correct socket and torque wrench for same.
Service reset
Oil filter 36mm socket 28nM torque
to read Oil level
Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows!
Oil reset pop bonnet, leave driver door open, press full. Brake and accelerator pedals for 10 secs
Lastly buy a cheap OBD2 tool and scan car for error codes and reset them scan again to see permanent codes that wont clear -follow up errors. I use this its cheap and cheerful and does the job for a basic DIYer
https://www.autelstore.co.uk/wholesale/aut...anner.html
Good luck 2018 SE SDV8 4.4 Byron Blue
Post #717263 2nd May 2025 9:20am
