Home > Technical (L405) > Topix - ZF filter change - SDV8 with DPF
SparkyMark837
United Kingdom 2016 Range Rover Vogue SE SDV8 Aintree Green
Hi,
I went to change my gearbox filter with a mechanic friend over the weekend and my friend was concerned that the filter might not come out easily as the exhaust pipe crosses over the middle of the sump rather than at the back like the non DPF versions.
I did enquire on a FB page and was told it does if you remove the vibration damper, but I wanted to see if Topix lists how to do a filter change?
I think it's not a service item according to LR so wondered whether they do show it?
I don't want to pay to look it up and then find it's not listed!
I would've done a search for Topix here but the search function doesn't seem to be working today.
Thanks - Mark
2016 L405 Vogue SE SDV8
Post #717535 7th May 2025 7:36am
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
No idea on the Topix side of things but can confirm if you remove the damper off the exhaust the sump/filter pan will come off, done my 2018 SDV8 a month or so ago, the workshop manuals in the Wiki might be something in there 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #717575 7th May 2025 6:02pm
Gremlin500
Nah, the WM in the Wiki above is 2016, and there is no exhaust present whatsoever! Crying or Very sad V6 Vogue - “Less is More” - less to go wrong!
Post #717595 7th May 2025 10:27pm
SparkyMark837
Thank you for the replies - perfect Thumbs Up
Post #717600 8th May 2025 5:43am
