Home > In Car Electronics (L405) > Damaged obd port
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Damaged obd port
Hi all
My obd port appears damaged and won’t receive a plug..
Does anyone where I can get a replacement and how easy it is to fit?
Thanks
Post #717601 8th May 2025 7:51am
Pawl
You need to have a good look to work out what the problem is.
If the L405 is same as the L322, the wiring & pins "part" can be separated from the plastic casing quite easily & the plastic casing easily removed - once you remove the panel it's mounted to (or if you can get to the back of the connector to release the mounting clips.
The plastic casing can be easily be replaced.
The electrical pins are likely to be crimped to the cables, so a lot more work to deal with if they're damaged. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #717623 8th May 2025 8:00pm
Kot
Re: Damaged obd port
Unnecessary quote removed
OBD2 Serial Port Connector, Ebay have them but no idea what the quality is like Whistle 2018 SE SDV8 4.4 Byron Blue
Post #717645 9th May 2025 9:37am
