Home > For Sale & Wanted > [For Sale] 1994 Range Rover Classic LSE Softdash
DavidL
1994 Range Rover Classic LSE (Softdash)
One of the last classic Range Rovers built with the dash from the, then incoming, Discovery.
Montpelier Red with grey leather, Cyclone Alloy wheels, Brooklands body kit and 4. 2L Rover V8 engine
Owned for the last 15 years and with copious amounts of work done by marque specialists Kingsley Cars, Lloyds Specialist Development and Southwest Rustproofing.
MOT April 26, no advisories. The dash mileage is somewhat irrelevant, it is a case of find a part that has done all those miles, very few (if any maybe) have.
It has underslung LPG tanks, so no intrusion into the boot space, but the car hasn't been run on LPG since the engine rebuild. Currently it uses the small petrol tank from the lpg conversion which gives a range of 50 miles around town and 70+ on a run. There is currently an unconnected open loop lpg system in place so it would be an option to update this to a closed loop single point system or revert back to petrol and replace the tanks with a new petrol tank.
Almost everything works including the air suspension, seat ecu (rebuilt), sunroof and AC .
Radio replaced with Becker single din satnav unit from a Freelander. I'm a great fan of Becker stuff, the quality is excellent on the whole.
Vredestein Quatrac V all season tyres with plenty of tread.
This car was used for the LR Classic Parts advert in 2000 and is supposedly the Montpelier LSE used in the adverts for LR 2000, pic enclosed, but I have no actual evidence for this. It was used for the LR Enthusiast article in June 2004 and a copy is included. It has been owned by several members of the Range Rover Register over the years.
Used sparingly and only very infrequently in the rain since.
A full set of badges will accompany the car.
New and replacement parts including but not exhaustive:
Repainted grill
New headlights
New steering damper
Rebuilt engine with real steel cam
Rebuilt front wings and bulkhead
LR branded Becker single din radio with satnav
Correct soft dash seats in excellent condition
Rebuilt seat ecu
Replacement rear quarter window rubbers
New headlining
Rear wheel arches and factory door extensions in good condition
Rebuilt air suspension valve block and compressor
Full SS stainless steel exhaust including manifolds
Underslung LPG tanks, no evidence in the boot, currently not connected and the car hasn’t been run on lpg since the engine rebuild
Small 30l petrol tank inside inner wing utilising the original filler.
LPG could be reinstated with a suitable closed loop single point system or a new petrol tank reinstated.
Extensive bodywork at leading marque specialists Lloyds Specialist Engineering, Warminster and Kingsley Cars, Oxford
Underside protected by SouthWest Rustproofing, Westbury
Work includes but not limited to
New front inner wings
Repaired bulkhead
Repaired floorpans
Repaired sills with some remedial work post MOT 2022
Repaired rear inner wings and wheel arches
Replacement boot floor, non ferrous replacement
Replaced rear cross member.
Repaired lower tailgate
New UK aluminium upper tailgate
New rear wiper motor
New brake booster
Comprehensive service history
Minor electrical issues –
Central locking inoperative
Rear heated screen inoperative
Please contact me through pm here
Car is in North Wiltshire for viewing
£10,000 or vno.
Post #717624 8th May 2025 8:34pm
dhallworth
That looks lovely, good luck with the sale.
Do you mind me asking who rebuilt your seat ECUs?
Thanks
Post #718171 19th May 2025 12:31pm
DavidL
I had it done locally, the father of a friend worked in that line and managed to resolder all the tracks that were damaged by the battery. Last time I looked there was a Bentley specialist who did them. It's slow and painstaking but not especially hard if you have the skill.
Post #718278 20th May 2025 10:46pm
