Home > Technical (L405) > Air suspension sometimes fills slowly
Flash
Sweden 2015 Range Rover Autobiography SDV8 Kaikoura Stone
Guess I have a few gremlins in the air suspension. I have tried to read everything and every post on the air suspension but can't really find a solution for one of my issues.
I Solved the first issue easily by drilling the exhaust silencer. Now the suspension lowers as it should when access height is selected. Before fixing the silencer it would more or less always go to off road height instead of lowering.
The other issue has been a bit more tricky. I have the code C1A20-64 "Pressure increase too slow". When starting the car the compressor runs quite long, maybe two minutes. If I lower the car and then raise it again the compressor only runs during the lift and then turns off directly when it reaches its level. It of course might be the compressor that needs replacing but since it is only slow sometimes I suspect something else is wrong also.
I have also had the occasional "Only normal ride height available" with disabling of the ACC and EIB and sometimes also the auto terrain response. Since drilling the silencer this only happened once in the last few days.
Anyone experienced similar issues?
Post #717653 9th May 2025 1:35pm
Kot
I had the same see this thread.
https://www.fullfatrr.com/forum/topic59778.html 2018 SE SDV8 4.4 Byron Blue
Post #717664 9th May 2025 8:18pm
Flash
Thanks Kot,
I've read your thread but my car is a 2015 which has an older compressor without the part you mention. I can't seem to find any equivalent part on the older compressor.
Post #717732 11th May 2025 6:57am
Flash
We did some tests yesterday and the reservoir seems to keep pressure when parked. I don't know however why the pump is running for so long when the engine is started as the pressure is not increasing during that time.
Post #717821 12th May 2025 6:25pm
