Home > Technical (L322) > Gearchange issues
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Gearchange issues
I wonder if anyone can shed any light on what my transmission is getting up to please? For the most part (ie 95% of the time) it's spot on, smooth changes, no hiccups etc. BUT, if you ask for brisk acceleration from a slow speed (not a standstill, say about walking pace) occasionally it gets all confused and bangs through several gears until it decides where it should be.
Car has 122,000 miles, all fluids were changed at around 80k miles (with gearbox flush) and the gearbox has been flushed again about 6k miles ago. This made no difference to behaviour. It's going to my indi shortly for a service and I'm getting them to look at things like propshaft centre bearing and engine and gearbox mounts, not that I think this is the main issue but they could all be a bit dodgy by now. I'm thinking this has to be an electrical or software issue.
Any thought? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #717858 13th May 2025 9:10am
cass
Were the fluiud changes done with real ZF fluid and to the exact level?
My old one misbehaved even when slightly underfilled.
Post #717863 13th May 2025 9:29am
rvbush
So far as I know, yes. I did check that the correct ZF fluid was used. Drives:
Post #717881 13th May 2025 2:43pm
