Home > In Car Electronics (L405) > Media failure
DaveBL405
United Kingdom 2019 Range Rover Autobiography SDV6 Balmoral Blue
Media failure
My 2021 AB has recently started to have periodic media failure - so as I drive along the whole media element of the system will stop working, so no radio, USB, Bluetooth or CarPlay. That function on the touch screen stops working and the dash just displays the car picture you normally get on boot up. I have to stop and turn the car off and on again and it sometimes resets. I also get as occasional USB errors - the radio still works but the USBs don’t, again either until I power the car off or sometimes when I unplug and replig the usb.
Recently I had an odd version of the media failure where the whole screen just stopped working - but ironically the media was fine and could be controlled via the dashboard. 20 mins into the drive it just rebooted and then started working again.
Either my car is gaslighting me or I’ve got a gremlin somewhere… any ideas???
Post #717940 14th May 2025 7:16pm
Dolphinboy
software update required? Chalky on this forum had loads of probs with his 2018. took 2 yrs to fix! Shocked
Post #718006 15th May 2025 9:27pm
DaveBL405
Car says I’m on the latest version…
Post #718007 15th May 2025 9:29pm
Chalky
As DolphinBoy says, I had terrible problems with the infotainment in my 2018 car which was the first of the facelifts.
My 2021 car however is much better, but even so, occasionally the whole thing has a mind of its own with ACP not working and the bottom screen going blank. It always resolves itself by switching off and restarting (just like an iPhone Whistle ). I suppose we have to live with all this tech which now and again needs rebooting Yawn Yawn
If it persists I'd take into a dealer and hope they have someone who knows what they're doing! All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #718028 16th May 2025 10:11am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
My 2020.5 MY does the same. No reason or logic, just switch off and switch on and it sorts it. 2024 - >. 2021MY L405 5.0 SC Portofino Blue
2018 - 2024 2016MY L405 4.4 SDV8 VSE Aintree Green
2017 - 2018 2017MY Jaguar F Pace Portfolio 3.0 SDV6 BRG
2013 - 2017 2010MY L322 3.6TDV8 VSE Buckingham Blue
Various RR Sports and Freelanders before that!
Post #718053 16th May 2025 1:37pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Although the car is rather new, check for water leaks from sunroof (if fitted) and earth connection under the left front wheel arch. Also 12V batteries. A diag tool & codes could help a lot.
Post #718055 16th May 2025 1:44pm
Gremlin500
It might be worth mentioning to check your battery SOH (not just SOC), I had a whole host of electrical er, Gremlins Laughing when I first got my FullFat, including infotainment/maps, but these just vanished when I replaced the weak battery, and the car has been amazingly reliable ever since. (He says, tempting fate Embarassed )
My battery was down to 29% SOH, yet still starting the car fine, but would it hell update anything, software or maps, etc. V6 Vogue - “Less is More” - less to go wrong!
Post #718058 16th May 2025 2:33pm
