![]() | Home > Technical (L405) > Charging Issues When Hot – Alternator Stops Charging |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
First thing to do is look for fault codes, you need a good independent or buy a Gap IID tool
lee.norg Member Since: 23 Aug 2022 Location: Manchester Posts: 22 ![]() ![]() ![]() |
Thanks Pete - i have an iCarSoft 3.0 and so far its not giving me any ideas.
Another question to ask. I've replaced the drivers side earth point with a new drilled rivnut and I've done the one in the boot (negative battery cable). Is there an earth point in the UK passenger front wheel well? I'm thinking that could be part of the issue? 2016 Range Rover L405 4.4 SDV8 Autobiography |
Yes there is, mine fell apart on touching it... Red circle is ground on car, yellow circle is the wires...
Thanks Pete, your response is appreciated. A job for the weekend and i'll see if that helps with the temperature charging issue. 2016 Range Rover L405 4.4 SDV8 Autobiography |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Have you logged the alternator output current as the regulator could be breaking down when it gets hot and actually putting a short onto the charging circuit, followed by 2 rapidly drained batteries. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
I haven’t no. I wouldn’t know where to start with something like that, so will have to ask a garage. Mechanical I’m quite good with IMO, anything electrical I have no idea. 2016 Range Rover L405 4.4 SDV8 Autobiography |
