![]() | Home > Technical (L405) > Engine performance has anyone else had this? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1879 ![]() ![]() ![]() |
I have the same engine and MY, but if anything it has MORE power when its cold out, (but the engine is up to temperature), which could be expected, I suppose. You really need to scan for DTC’s to see if a sensor has malfunctioned, do you have an OBD scanner like an iiD tool or similar? There could be a number of reasons for rough running. V6 Vogue - “Less is More” - less to go wrong! |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
In the L494 if temps are low the vehicle alters the engine map to dull the acceleration, very noticeable (even the Mrs commented). If you press the terrain button and let it rise, that takes it out of auto mode and normal values are applied, give that a try. I think it applies the ' car knows best' setting if the temp warning is on, so 4 degrees and below.
