Home > Technical (L322) > Lost Drive / HDC Transmission Fault / U0402-xx Codes
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi All,
So.. I had this problem a week or so back and after checking the alternator was working fine - it was and is less than 4 years old (genuine part), I changed the Battery for a YBX5019 Yuasa Silver High Performance Car Battery 12V 100Ah HSB019 one, as the one in the SC was around 6 years old, knowing that a failing battery can cause the issue below...
..which was .. driving along, doing a steady 30mph when all of a sudden I lost drive and all the engine would rev freely despite being in drive... I moved it in between gears but now joy and left it in Park with the handbrake on.
Whipped out the IID Tool and these codes popped up -
IPC-Instrument Pack
U0402-68 (2E) Invalid data received from transmission control module - Algorithm based failure - event information
( on 21-05-2025 22:03:54 at 96672 mi )
PCM-Engine Petrol
U0402-81 (36) Invalid data received from transmission control module - Bus signal/message failure - invalid serial data received
U0402-86 (36) Invalid data received from transmission control module - Bus signal/message failure - signal is invalid
VDM-Vehicle Dynamic
U0402-68 (0B) Invalid data received from transmission control module - Algorithm based failure - event information
( on 21-05-2025 22:03:51 at 96672 mi )
I cleared the codes and then proceeded on my way without issue for another 15miles until I got home.
Anyone have any wise words as to what this could be? I'm thinking along the lines of a circuit in the mechatronic unit in the Gearbox ? Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #718372 22nd May 2025 6:25pm
Superspoons
Any ideas anyone ? Gavin
Post #718669 27th May 2025 10:14am
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Had the same after a gearbox oil and filter change. Can’t remember the codes, but it felt like the clutch cable had gone on a conventional clutch car.
Cleared the faults and drive home and all was fine. I did have a dicky suspension issue at the same time, which was a dodgy wire, but 2 months in and I’d forgotten all about it.
Post #718676 27th May 2025 2:49pm
dhallworth
Hi Gavin,
My old 4.2 did similar to this and I changed the gearbox when it was the transfer box that had failed.
Have a read of these 2 threads:
https://www.fullfatrr.com/forum/topic59943.html
https://www.fullfatrr.com/forum/topic59970.html
Also page 11 on this thread:
https://www.fullfatrr.com/forum/topic57991-150.html
Do your comms faults clear or do they come back the second you start the car?
If you can clear them, are you able to switch between high and low range?
I'd also drain the oil out of the transfer box if you can as mine was shiny when this happened to mine.
Post #718679 27th May 2025 3:25pm
