![]() | Home > Technical (L405) > Oil consumption and boost fault |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2712 ![]() ![]() |
Look inside the oil filter housing to check if the drain plug is still complete and where it should be. The spring can detach and the rubber plug can disintegrate, allowing oil to flood the crankcase oil/air separator pushing oil into the primary turbo air intake. L405 D350 SE Carpathian Grey D5 19" rims |
iainvr4 Member Since: 16 Mar 2013 Location: glasgow Posts: 45 ![]() ![]() |
Thanks for that will give it a check |
Look at that and there is no spring or seal at the bottom of the oil filter housing |
Does that mean there is an open hole or has the design changed to not have the drain hole? L405 D350 SE Carpathian Grey D5 19" rims |
I take it has changed the design I look for pictures and seen the style with the spring so it definitely wasn’t like that. Back to the drawing board 🤦🏼♂️ |
