Home > Maintenance & Mods (L405) > Gearbox oil change
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Gearbox oil change
My 4.4 has done 86k miles. Should I be thinking about changing the gearbox oil and any filters involved. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #718401 23rd May 2025 12:35pm
dhallworth
JLR state that the gearbox is sealed for life... however, ZF recommend servicing the gearbox between 60 and 80k miles depending on usage.
If it were my car I'd definitely be having the gearbox oil changed as prevention is a lot cheaper than a cure when it comes to gearbox issues!
A lot of local specialists have a machine to flush the gearbox or you can find the details for a chap called Ian Bodsworth (his company name is updates by bodsy) who travels to you and can flush the gearbox, change your diff oils and transfer box oils on your driveway for sensible money. A lot of people have commented on how good his service is. Thumbs Up
Post #718404 23rd May 2025 1:20pm
Mikey
50-75k, or 7 years, from ZF Thumbs Up
Post #718431 23rd May 2025 8:24pm
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
First thing i did when i bought mine.
Prevention much better than cure.
Get it done.
Post #718432 23rd May 2025 8:48pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I would certainly go with the advice from ZF rather than JLR. They are clear on the need to service it.
I serviced my gearbox last year when it was 8 years and 60k miles by using 20L of oil to complete 3 oil changes (driving 100 miles between each) and then on the 4th oil change I also changed the filter pan.
The oil that came out was pretty dark so I think it was well worth it.
A genuine filter was £100 and I used Smith & Allen Lifeguard oil that was also circa £100. If you use ZF branded oil it is circa £30 a litre.
Or you are looking at around £400 to £500 for a garage to do it.
Post #718456 24th May 2025 8:11am
robmeister1969
United Kingdom 2018 Range Rover Autobiography SDV6 Corris Grey
Just had a quote for gearbox and fluid service - £1,700. They must be busy! Current > FFRR 2018 3.0 SDV6
Past > RRS 2015; RRS 2005; RRS 2007
Post #718730 28th May 2025 3:49pm
