Home > Technical (L322) > P065E00 Intake Tuning Valve
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
I am chasing down this code that has recently appeared. It appeared after I changed the coolant reservoir and I am wondering if I disturbed something (like a vacuum hose) when I was replacing the reservoir or is the code unrelated.
Is this valve located at the front or rear of the engine and am I right in thinking there are two, one for each intake manifold? The code I have refers to Bank 1 which I think is the same (right hand) side as the coolant reservoir. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #718750 28th May 2025 9:27pm
