![]() | Home > Technical (L322) > Retrofit rear reclining seats, can it be done? |
I did it on my previous 322. A 2011/12. I simply found someone breaking a front end damaged model with reclining rear seats. Everything was bolt on and simple enough… If you go and search my 2011/12 grey 322 then I’m sure I included it in my story? Feel free to come back and reach out if you need more information sir… |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1243 ![]() ![]() ![]() |
Great info Craig, I'll keep my eyes out at the breakers, would be interesting to try out. Tom
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87 ![]() ![]() ![]() |
isn't the rear cargo cover / parcel shelf slightly different to allow for the movement 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1524 ![]() ![]() ![]() |
The parcel shelf is different (that's unicorn too), you would also need new door cards and that assumes the wiring loom is the in the doors already (that's both doors), as recline on rear seats is controlled via door cards, also its both door cards.
I've managed to source some matching AB door cards with the full heat cool option switches. Not sure if the existing door card loom has the plug blanked off but will find out soon.
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 67 ![]() ![]() ![]() |
Don’t forget the rear parcel shelf, as someone mentioned, to add to your list. It has two hinged flaps to allow the seats to recline. I have them in mine, no 4 zone climate. Shout if you need any pics. 2010 Supercharged |
I was thinking it might be possible to butcher a standard parcel shelf and cut in a hinge flap in line with the seat divide.
exyjerome Member Since: 24 Mar 2025 Location: Hampshire Posts: 33 ![]() ![]() ![]() |
Currently an Autobiography up on Copart with rear reclining seats, would probably make the retrofit a lot easier!
