Home > Maintenance & Mods (L405) > Unusual noise after revving, any ideas?
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
hi all, I have started to notice an unusual noise, primarily on the drivers side, after revving the engine. It sounds a bit like a release of vacuum pressure or maybe a bearing or pulley rattle? I have attached a link to a short video where you can here the noise just after I rev the engine.
I know it is a long shot but can anybody identify a likely culprit?
https://streamable.com/50jnq9 _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #718890 31st May 2025 1:51pm
kevinp
Mine made a similar noise on the over-run when I'd damaged my MAP sensor.
Worth taking a peek to see if it's dirty? Long shot! Worth a look.
Post #718897 31st May 2025 3:33pm
ReggieMac
I will take a look at that, I am glad you could make the noise out from the video and it is not just me imagining it! Thumbs Up _______________________________________________
Post #718899 31st May 2025 3:55pm
ReggieMac
Just a little more info after looking at the car again
- Type of Sound: It resembles a vacuum-like hiss or a whirring bearing noise.
- When It Happens: The noise is noticeable when revving the engine and becomes more pronounced on overrun as the revs decrease.
- Where It’s Coming From: It seems localized to the driver’s side, possibly from the engine bay.
- Variations: The sound might change in pitch or intensity depending on engine speed.
To be even more precise, you could compare it to familiar noises, such as:
- A leaking vacuum hose
- A dry or worn pulley bearing
- A faint turbo whistle or blow-off valve soun _______________________________________________
Post #718901 31st May 2025 5:53pm
