![]() | Home > Technical (L405) > 2019 L405 ATB LWB deployable steps not working - RESOLVED |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1878 ![]() ![]() ![]() |
You first need to scan the car for DTC’s with a tool such as the GAP iiD G4 tool, otherwise you might replace parts unneccessarily.
noone Member Since: 05 Apr 2025 Location: Florida Posts: 97 ![]() ![]() |
I’ll spray the heck out of the shafts with some silicone spray tonight.
You really need to scan for error codes first, no point in lubing up if there is a system fault/no power, the steps won’t even try to move. Usually, if its just sticky hinges, the steps “twitch” a little then stop.
Yeah, the motors and steps are clean as a whistle. No rust or corrosion. Florida vehicle.
Help me play this out please.
This is not the way to go, the diagnostics provided by the manufacturer and by GAP are there for a reason. If you try to guess what might be wrong, such as by opening up old connectors which might just still be watertight until you plug them in again after finding no apparent issue, you run the risk of then introducing further faults. Take it to a qualified auto electrician, and pay for an hour or two of proper investigation is my advice, you will save money in the long run. |
Previous owner, original owner said he turned them off because it was hitting his shins and he’s 6’4”. I have no reason not to believe him. They just don’t turn back on.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
See attached, the module is in the rear boot (trunk/luggage space) left hand area maybe item 2 is unplugged? (page 7) or the fuse is removed in fuse junction box in rear space (right hand side panel).
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 53 ![]() ![]() ![]() |
Take one of the steps off, only 4 bolts from the underside. Then see if the front hinge moves free. That may give you an indication of the issue 2018 4.4 TDV8 |
That is hard to believe, -on approaching the car surely you’re expecting the steps to deploy so you can get in? And his private parts would have to be just about touching the door, in order to get a whack on the shins? It sounds like a lame excuse to me, maybe he knew the steps were fubarred so he disabled them to sell it? ![]() |
Actually its not difficult to smash your chins, I park in a off road forest car park when taking the dog on walks, that is very uneven, and sometimes when I come back the steps do not deploy until I reach in and press the ignition button |
You cannot take off the step itself when the step is stuck deployed. That’s what’s making this a bitch to troubleshoot. I checked the fuse and it’s fine. Will check the module tonight to see if it’s plugged in. 2023 L460 Range Rover SE P400 2019 L405 Range Rover ATB LWB |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410 ![]() ![]() |
You can take the step off when it's deployed or not. It's just four allen bolts, two on each step. From there you can see if the front hinge is stiff, and then you can remove the back hinge and motor together as one. 2017 4.4 SDV8 Autobiography in black
My factory steps are tucked into the molding. About 3/8” gap. I could not get it off the track high enough.l to clear the molding. 2023 L460 Range Rover SE P400
