![]() | Home > Technical (L322) > Removing fog lamp assembly on 2012 with design pack bumper. |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 36 ![]() ![]() ![]() |
Circling back to provide closure. The fog lamps are bolted directly to the back of the Design Pack Bumper (see vid below). So, to remove them you will have to either remove the bumper, or perhaps you can get away with removing the wheel well and get to the lamp unit that way. If you just need to replace a bulb, going through the wheel well will probably work.
