![]() | Home > Technical (L322) > Oil pressure sensor/switch |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2723 ![]() ![]() |
It screws into the front of the RH cylinder head, just above the oil pump. RH is when looking forward from the rear to the front of the vehicle, not when standing in front of the vehicle looking at the engine. L405 D350 SE Carpathian Grey D5 19" rims |
Digitalstorm Member Since: 07 Jun 2025 Location: London Posts: 5 ![]() ![]() ![]() |
Much obliged sir!
Yes.
What on earth…
Can you catch the coolant? You might have to disconnect or remove other pipes/hoses and possibly the serpentine belt to get access. L405 D350 SE Carpathian Grey D5 19" rims |
Went for the ecu box first.
Sorted!
The 4.4 has a bracket for a coolant pipe in the same area.
