|  | Home > Maintenance & Mods (L322) > L322 intermittent heater |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Most likley the common issue of the heater control valve
|  8th Jun 2025 3:45pm |
| Vogue66 Member Since: 21 Nov 2024 Location: Cornwall Posts: 9      | Hi, thanks for that.
|  8th Jun 2025 5:30pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | You cannot by pass it for that very reason it's the control valve. Different engine speeds effect the coolant flow......that's what I experienced when mine went faulty. | ||
|  8th Jun 2025 6:14pm |
| Vogue66 Member Since: 21 Nov 2024 Location: Cornwall Posts: 9      | Okay thanks I’ll look into changing it then and hope that solves the problem.
|  8th Jun 2025 6:17pm |
| fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 70    | Gates EHV133 is the OEM part. Don’t bother with cheapo copies from the online auctioneer - ask me how I know - the Gates part isn’t much more expensive and is considerably better (original) quality.
|  9th Jun 2025 12:30am |
| Vogue66 Member Since: 21 Nov 2024 Location: Cornwall Posts: 9      | The gates one looks different to mine, I think that maybe for the FBH. Mines a 2 solenoid one looks the same as the above eBay link.
|  9th Jun 2025 12:46am |
| Vogue66 Member Since: 21 Nov 2024 Location: Cornwall Posts: 9      | I’ve changed the heater control valve, but the old ones were all broken up, so they needed replacing.
|  13th Jun 2025 2:16pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | As you have now proved it was the control valve and it was all broken up and have poor heating 1 side of the car compared to the other it proberly means those broken up bits are blocking the heater matrix.
|  13th Jun 2025 7:58pm |
| Vogue66 Member Since: 21 Nov 2024 Location: Cornwall Posts: 9      | I flushed out the heater matrix when I did it to make sure there was no blockages.
|  14th Jun 2025 4:34am |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Yeah temp gauge should stay in yhe middle I suspect an air lock.
|  14th Jun 2025 6:29pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
