Home > Technical (L405) > SDV8/TDV8 fuel return line questions
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Hi, I'm writing in hopes someone may be experienced with how a SDV8/TDV8 fuel return path works. I've just sent my injectors for testing and they came back within factory specs so no problems there. As I started tracing on how the return fuel line works I seem to have stumbled across some oddities on the design.
Based on the diagram:
2. Injector leak off return line. 8 injectors return merged into 1 hose which connects to (2) (A) return line. The line later merges with the T joint (B- no 1 way valve) but connects in between of low pressure lift pump and the fuel heater (5) (C) before going back into HPFP.
As I understand the low pressure pump delivers a constant 5 bar fuel pressure. Would this mean the T joint (B) is constantly pushing fuel back to the injector leak off pipes? I tried pushing low pressure air through (A, B, C) openings and air can escape from either ends.
Should the injector leak off return be better being routed back to (3) line as this is the hose where the excess from HPFP and fuel rail being released back into the fuel cooler which ultimately goes back into the fuel tank?
The system doesn't look right to me and I'm not sure if I'm missing anything out. Appreciate your inputs. Thanks.
Post #719473 9th Jun 2025 3:11pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Let me take a stab at answering this. Though someone more knowledgeable can probably do a better job.
As you have pointed out there are two possible Low Pressure lines the injector leak-back fuel can go.
1. Fuel return from High Pressure pump and Pressure Relief Valve. At less than 1 bar of pressure and sometimes even under slight negative pressure. Goes back to the tank through the fuel cooler.
2. Fuel feed to the High Pressure pump. At around 5 bars as you pointed out. Output of Low Pressure pump that goes through the filter.
There are two considerations when deciding where to dump the leak-back fuel.
First, if you think of it in terms of relative pressures and improving overall pumping efficiencies, you have 100s if not thousands of bars of pressure on the inlet side of the injector. So the injector has no problem dumping its excess fuel into a fuel rail that is at a measly 5 bars of pressure. In fact, you just saved some energy by not having to compress that leak-back fluid back up to 5 bars so that it can be ingested again by the High Pressure pump.
Second, and perhaps more important reason, is the piezo fuel injector has a small hydraulic (fuel filled) amplifier in it that couples the stack of piezoelectric ceramic disks to the valve needle in the nozzle. The piezo disk stack has a very small amount of movement (less than 0.1 mm) when energized. This amplifier, also known as the hydraulic ratio transformer, converts that small movement into a larger stroke which then moves the needle. If there is very low or negative pressure (vacuum) on the overflow side of the injector, then the fluid in this hydraulic amplifier drains away. And the amplifier stops working. Causing the whole injector to stop working. This is why having a little +ve pressure on the leak-back side of the injectors is important.
This video at the 4:10 minute mark shows what the amplifier module looks like and how it functions.
[/list]
Post #720606 1st Jul 2025 8:07am
