Home > Technical (L405) > Slightly shakes at low idle and rumbles at 1k RPM
noone
United States
2019 ATB LWB.
Noticing that there is some slight occasional shaking of the vehicle when at idle parked in the garage. It’s older with 98k on the odometer. Idle rpm’s are consistent. Is this normal or should I check something like the motor mounts? If I open the hood and rev it some, I do see the engine move, not a lot like I’ve seen some move but it definitely moves. The left drivers side (left hand drive) moves up when revving.
Other issue - at 1k RPM car feels like it’s running over a badly grooved paved street, if that makes sense.
Maybe the two are related? 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #719492 9th Jun 2025 8:24pm
