Home > Maintenance & Mods (L322) > 2010-2012 Rear Shock lower nut & bolt?
JMC
Just wondering if anyone can confirm the part# for the lower nut and bolt on the rear shocks?
About to change the (CVD) rear shocks, but looking at the state of the nut in particular, I'd like to replace them. I'm finding RYP000111 being quoted for the bolt on some sites as being for up to 2006 only whilst a few are suggesting this bolt does them across all years. Can anyone confirm please? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719525 10th Jun 2025 11:07am
GraemeS
Australia
That is the correct part number the bolt for MY10-12 according to Microcat 2012. L405 D350 SE Carpathian Grey D5 19" rims
Post #719530 10th Jun 2025 11:51am
JMC
Thank you!
After getting it all off, I have discovered that there's actually nothing wrong with the nut and bolt - just a load of crud making it look like it was beyond re-use!
Now I just need to find the torque settings...... Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719544 10th Jun 2025 3:20pm
GraemeS
Australia
Only 90 Nm. Tight enough to not work loose has been my practice. L405 D350 SE Carpathian Grey D5 19" rims
Post #719566 10th Jun 2025 9:48pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Hi JMC,
Would you mind sharing how much you managed to buy tge shocks for, brand and how easy is it to replace the rears?
Many Thanks
Brian 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #719570 11th Jun 2025 1:57am
JMC
@Eastsoutheast - Bilstein CVD shocks were £199+vat each. The strut top gaskets were £3.69+vat
https://www.island-4x4.co.uk/
Three 16mm nuts up top from inside the boot, disconnect the CVD while you are there, and one big 21mm at the bottom for each shock. Childs play if you are up to any kind of automotive DIY. Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719573 11th Jun 2025 7:13am
Eastsoutheast
Thanks JMC, appreciated 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #719578 11th Jun 2025 11:16am
